Awd sypder swap help question
1fast97gsx
4,517
17
Jul 6, 2003
Orland Park, Illinois
Im in the process of doing an awd spyder and the write up i read shows the front knuckles/hubs/ control arms all get swapped over from the awd car. Is this just to make things easier or are the knuckles/control arms different? I want to install new axles and wheel bearings anyways, so in other words can i just remove the spyder axles and bearings in the front and bolt on awd bearings and axles without touching the rest of the front suspension? Thanks.
I got the answer from someone on this and just in case someone else has this same question ... everything in the front is the same except the axles. Basically you just install AWD axles FWD and you're good to go. Please close thread.
