AWD Swap drive shaft question.
2gTurBoD
59
Jul 25, 2007
orange park, Florida
I have all the parts necessary, except the two drive shaft mounts I need. I cant find a parts car remotely close to me so Im not sure how to proceed. Is there a possibly way to go to the dealership and order these parts, I cant even pull up a part number. I read a few threads were, people were talking about welding bolts onto the fwd mounts, but those wouldn't have the exhaust hangers on them, which I read could be welded in. If I went this route would this work, for both of the two mounts. This is the only thing stopping me in my swap. Can someone help me out, with it. If possible Id like to get the AWD mounts. Ive searched through threads but never found the answers I need, or Ive been using the wrong terms. And Just incase some people are unaware which mounts im referring to. Thanks
I got mine from Miller import parts. Miller Import Parts He's on here as Stangmurdera DSM Forums - View Profile: Stangmurdera He's on ebay too as importpartsman.
I had a donor car but there was some rust and Stephen helped me out with the carrier mounts. Tell him He owes me a cookie!
Your other choice is a donor car. BTW I wouldn't mess with replacing the front driveshaft carrier bearing mount. All you have to weld is two exhaust hangers on your existing one and drop in two bolts. The holes are already there. Easier IMO.
Oh another thing you could do is not even go with the front driveshaft bearing carrier and stick a DSS driveshaft under there. You will still need the rear mount and that part of the stock driveshaft to the diff. Then all you have to worry about is exhaust hangers to weld on.
