Drive shaft rattle
boost_or_bust
97
Jun 19, 2004
Bismarck, North Dakota
I have a 91 talon and the drive shaft rattles or wobbels when i get on it around 3-4k RPM...Im pretty sure its the mid-ship bearing because the rubber cushion is gone on the bearing...anyways just wondering if anyone has had this problem. How much does it cost, is it hard to change, and if anyone has a pic of one that is in good condition i would appreciate it.
Thanks
bearing is about $55. not too hard to change, need an impact gun and or to be able to pull a universal joint out. check the vfaq.com. Also, there are 2 bearings, might as well spend the money and do both.
