AWD Launch
It was doing nothing but spinning all the way through first when I was letting the clutch out faster :)
You were on the clutch way to much! Did you smell clutch after wards?
Spinning is good
Hooking is what makes your break parts
Keep that in mind
Nah the clutch doesn't smell - just so you guys know, it was because I was using E-Brake to load suspension - maybe giving you the impression that I was on the clutch too much. The car was on 9psi with a big16.. Oh well, it works :)
Spinning is good
Keep that in mind
I remember reading the a magazine article where they interviewed a certain person with the fastest awd dsm ;) and he said his technique is to rape the clutch to save the drivetrain. Spinning is not that great when you wheel hop and blow out the rear axle. Change your discs regularly or keep trying to find 4 bolts which are not getting easier to find.
