spadepro22
- 1,206
- 14
- Mar 13, 2008
Seneca,
South Carolina
Thinking about a motor rebuild and want to know at what power level will titanium and ss valves be needed? I plan on going with manley springs and kelford 264s.
So who sells a good spring/retainer kit?
What is the part number for Keford 264?
I don't have a part # for the cams, they will be orderd by force eng.(they are building the motor if I decide to rebuild)
Will stock recut valves, stock retainers, manley springs, 264 kelfords be ok to take to 8k?
Is that the combo They are suggesting you to run? Then the builder has done the math and deems it a solid set up.
You have to trust your enginebilder.
But with out the cam specs or part number, I can not give you an awnser.
272 at first, but I told them I wanted better spool time since its a street car. I do trust the builder. Just asking, because in the future if I wanted to make more power Im weighing my options to get them now. I was wondering the kind of hp numbers that kinda requires them. If that number is above any goal in my future, then I won't need to get them, but if its close, it would smart to go ahead and get them now.
Buy stock evo 8/9 springs and retainers. They are beehive springs and are good for 8.5k.
Stock valves will be just fine as long they are one piece. If your changing /replacing valves ss valves from gsc would be really nice.
I'd suggest hks 272s with that.
I am also trying to find out what spring to run with my hks 272s. I'm leaning toward a stock head besides cams and maybe crower springs but I'm not sure what is a NEED for big power.
Stock springs new might be ok. Most springs have 150k+ miles and 20 years of use. I wouldn't trust them for the cost of a new set of Manley springs.
