Upgraded valves, springs and retainers needed?
white7g
May 7, 2015
Charleston, South Carolina
Hey im building a 7th gen galant will have a 4g64 bottom end with eagle rods and wiseco pistons, and a 1g head. Is it necessary to upgrade the factory 1g valves and valve springs? Car will be revved to 7.5k and wont be over 450-500 hp in the future. Just wondering if I need to spend the extra 500 or if it can be used elsewhere.
I would suggest some new valve springs, normally the age of the spring and the mileage on them have weakened them.
If you are staying with a stock cam, or a smaller 272 like BC, HKS or the Comp/FP2 about any single spring with the stock retainer will be fine.
As long as you have the factory 6T valves you will be ok.
Thank you that us what I was thinking was worried bout the miles on them. is there any brand springs u would recommend I was looking at the single gsc behive springs that you can use with factory retainers.
I was in this predicament a week or so ago. I'm running a stock rebuilt 6 bolt with Web 546/547 cams and plan on running it out to 7.5k and around 440awhp. Bogus recommended the BC 1100's with stock retainers.
awesome good to know thank you all for the help im sure I will be back with more questions!
