fmic+fuel or cams+springs and retainers???
turboedspyder
103
Feb 28, 2007
Shillington, Pennsylvania
alright, so i have $600 to spent and am not sure which way to go with it. i was thinking of getting a fmic, 190 fuelpump, and wideband. that would help me in the long run because im gonna be looking to push 22 pounds on my garrett big t28. but then i thought a nice pair of fp2's and some springs and retainers would be nice. i was just wondering which choice would give me the most power for now. eventually i will be getting all that and more, but for now which one would give me the most gains?? only runnin 15pounds right now and mods in profile. thanks a lot
Definitly go with the FMIC,Fuel pump and wideband. Your going to need the fuel pump if you want to push 20+ PSI. Also the wideband will be key to dial in your tune. Yes cames would be nice, but they are not really needed right now if you have a tight budget.
FMIC+Fuel. No question about it. You need the fuel in order to turn the boost up. You need the fmic in order to not heat soak the intercooler during a run. Cams are for when you have all the supporting mods already. Also, you don't need to buy aftermarket spring to run fp2's, but they are good to have. I rev to 8,000 with fp2's on stock spring.
bling5tatus- What is even the point of posting if that is all you are going to say? That doesn't help the original poster at all.
alright, thanks for the help. i thought that would be the best way to go. after that then ill just get injectors and an safc. then work on the head.
Its not on your list BUT id save a bit more and get dsmlink! you'll thank yourself later on down the road. But if your gonna choose between those two i say go with the intercooler and fuel upgrades and you'll get some decent power out of that t28.
