arp studs question
dsmotors95
93
Jun 16, 2012
spring valley, California
so i bought some studs a while back but i cant remember if they were head studs or main studs..is there any ways of knowing what i have? they were used and dint come in a box so i don't have a part number.
LOL@math
Can you measure them? main studs are 10mm diameter and approx 95mm long.
7 bolt head studs are 11mm diameter and longer.
If the studs measure 12mm diameter they're for a 6 bolt.
Diameter.
Main Studs are a 10mm ARP 207-5401 and torque 60 ft/lbs with ARP lube
6 bolt head studs are 12mm ARP 207-4201 And torque 90 ft/lbs
7 Bolt head studs are 11mm ARP 207-4203 and torque 80 ft/lbs
If you have main studs, they will not even thread in to a head bolt hole in the block, just fall in.
Main stud nuts use a 12pt x 12mm socket
6 bolt head stud nuts use a 12pt x 14mm socket
7 bolt head stud nuts use a 12pt x 13mm socket
Each kit will have
(10) studs
(10) washers
(10) nuts
(1) Pkg of ARP Ultra Moly lube (blue package)
Each kit will have
(10) studs
(10) washers
(10) nuts
