ARP mains and head studs
They will come with torque specs in the box. Be sure to use the lube that is supplied with them on the threads, both sides of the washers and under the nut.
After installing the main studs you'll also want to check the align bore in the block. Often times the studs will distort the housing bores.
Yeah in the ARP box it just show the torque specs dosent say anything about stretching them or anything of that nature
You only need to achieve their recommended torque spec and nothing more. That value will preload the stud to the correct amount.
