ARP head studs...65 or 81 ft/lbs??
vlaar
216
Oct 9, 2002
Got my ARP's in the mail today :D On the "instructions" sheet, it says to torque (preload) the fasteners to 81 ft/lbs. (with moly lube). However, I was reading on the forms and a guy who called ARP said to torque them to 65 ft/lbs WITH the molylube... I'm thinking 65 sounds like a better torque number (81 is a bit high).
Kevin
65 is for stock headbolts....75-80 for apr's. i have mine torqued to 85
Cool. I guess I'll do the 81 like ARP suggests. My mechanic is actually doing this for me as I'll be out of town. It doesn't matter which studs he torques down as long as it's in a criss-cross pattern, correct? Thanks.
Kevin
start from the middle and work your way out, going from side to side...in the order below order. do 30, 50, then 80.
7 5 2 4 10
9 3 1 6 8
  • Wanted 6 bolt NT water pipe
    • chrisman287
