Arp Head Stud question
jlog1506
83
Sep 9, 2013
Roslyn Heights, New York
Okay well Ive been doing a little research and cant seem to find and answer. This may seem like a dumb question because it is. But when putting in the studs does the side with the longer or shorter threaded section go into the block. I would assume the longer section but I want to make sure. Also I put the head on the block before the studs. Its sitting there now not torqued down. I know its ridiculous but....
As stated above, there is one side that has an allen head. This side faces up away from the pistons. The stud should be run down just until the threads bottom out but not torqued.
Next the nut is tightened to the specified torque using their recommended ARP moly lube.
Post number 21 will is how I installed mine.
http://www.dsmtuners.com/threads/1990-eagle-talon-sleeper.427853/#post-152904014
Robert
