gofer
Moderator
- 8,164
- 1,549
- Feb 18, 2006
South Gilbert,
Arizona
E85 is badass, I think its a great idea but if your ordering it by the barrel then it seems sort of like a pain in the butt. Of course its up to you to decide, since remembering to order a barrel could mean getting to work or not where as I can fill up on my way just like gasoline.
Any amount of boost you want to run 16, 20, 25, or 30psi it doesn't matter your going to be able to put down more power running E85 than you would 93 octane. I'm currently running 29psi on a STOCK 7 bolt with 100k on the bottom end, my mods and hp numbers are all up to date in my profile.
Back to the question at the top though, that setup will be just fine on E85 but I do suggest upgrading to a metal fuel filter since the E85 eats the stock paper one. My HTA68 pushes 48 lbs/min and I'm running 950cc injectors, of course they are maxed and my fuel pressure is set to 55psi to get every last bit out of them but they are still doing just fine. You'd be lucky to see much over 40 lbs/min out of a 16g so those 1050's are good to go.
How bout we get some English racing guys in here and let them know that they are doing it all wrong as well.. WTF
