- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- GT35 Variant
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Drag Race
- Mods-Bolt-on
- JMFab Drag 2G SMIM
S90 70mm TB
Old school DNP T3 Exhaust Manifold
Precision Ball Bearing 6262 with .82ar T3 turbine housing, v-band outlet
Tial MVS 38mm EWG with 21psi springs installed
ETS 2.5" IC piping with PTE core
- Mods-Engine
- 1990 6 bolt
Manley 8.0:1 Pistons
K1 Rods
King bearings
2ga head
Kelford 272 cams
Manley single springs and retainers
Kiggly HLA
ARP head and main studs
- Mods-EMS & Logging
- 1990 0EPROM
ECMLink V3 full
ECMLink SD harness
Omni 4 bar MAP and GM IAT
Innovate LC2 wideband
- Mods-Drivetrain
- Unknown built trans with welded diff, stock 4 bolt lsd, some sort of heavy-ish pressure plate with an ACT 6 puck disc
- Parts Wishlist
- 8.50 chromoly cage, seats and harnesses, Hot parts kit from Morrison Fabrications, dogbox, BP shifter and cables, TMZ t-case, DSS driveshaft... etc
- Background
- Friend of mine has built numerous DSM's over the years; he did an excellent job on this but hit a brick wall so I saved this one from a part out to complete the detail work.
Goal for the car was originally 10.99 on the FP Green. I've since destroyed said turbo and installed a Precision 6262 in its place, so the new goal is looking like a 9.99 so it's going to take some more time and effort to complete.
