are 90-94 clutches the same as 95-99?
1sick1g187
Jan 24, 2012
Ohare, Illinois
ok im just a little confused im shopping for a clutch for my 1g 91 talon tsi awd, and i have 2 options, i have a guy with a brand new clutch kit from his 98 gsx since he upgraded to a track clutch or go with an oe replacement clutch, i was at the parts store and the part numbers are the same and also even when you go to extreme psi it shows 90-99 and you have no choice of what you want to pick. are they all the same?
Clutch discs and pressure plates are universal and will work with any 1G or 2G regardless if they're FWD or AWD. Flywheels are what's different, they're obviously 6 bolt and 7 bolt specific as well as FWD and AWD specific.
im using my flywheel thats on the car. so i dont have to worry about it not fitting right? or do i need a 2g flywheel if i use a 2g clutch?
