Apexi Turbo Timer Install
VeryFast2gDSM
61
Mar 22, 2009
Buffalo, New York
I picked up a used Apexi Turbo Timer and harness from a 1g.
The PnP Harness plugs right into the 2g, but when removing the key, its not keeping the engine running. Do I need to swap cables on the PnP harness to make it work on the 2g?
the harnesses are identical, problem is there are switched pins between 1g and 2g, off hand i cant remember which ones, also (my memory sucks so dont quote me)-but i think u may have to ground the "e-brake" circuit if you dont plan on using it as i think it sees an open circuit as the brake being down. google "APEXi turbo timer install" and find the pdf install file. as long as that is all done right the "pnp" harness should be your only problem.
no no its all good. I just know it was there ### I had to look it up a couple weeks ago myself and found it LOL =]
