apexi turbo timer install
Drewcool2
234
Jun 15, 2003
Downingtown, Pennsylvania
Just wondering if anyone knows which pin on the ecu is the ecu ground. The instructions say that when you hook up the white wire to the o2 readout(pin 76), that you are not supposed to ground the black wire to the chassis, and you are supposed to connect it to the engine ecu ground. So where is the engine ecu ground?
anyone have a link to a write up to install this? my apexi turbo timer is out for delivery today :) i have never done one and i dont know how hahah does it come with a plug and play harness and then you need to put one in the 02 pink the ebreak pin and the ground? which pin is for the ebreak and o2? i think i have my wideband pinned to the rear o2
