Anyone Running Kelford TX276HL?
willyp42
60
9
Sep 28, 2016
Windsor, ON, Canada
currently rebuilding a 6bolt (bare block right now) with a PTE 6262, wiseco HD pistons and eagle rods.
has anyone run this cam with no problems on stock lifters/followers? will obviously be grabbing a set of aftermarket springs.
thanks,
-Will
I had been running that cam set. no problem with stock lifters and rocker arms. But the 276/272HL has 12.50mm/12.00mm lift, so just make sure to use springs that can support that. Otherwise the bottom of the retainer and the top of the valve seal will contact. The Kiggly high pressure beehive springs or the Kelford beehive springs will work just fine without lowing the valve guide. I used the Kiggly high pressure beehive springs.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
