RacerXXX
- 0
- Apr 7, 2003
Anyone have oil filter that comes loose on 2nd gen AWD.
I was thinking If a safety wire, on the oil filter will keep it from coming loose.
Thanks,
Jim
Thanks,
Jim
). I'm not saying that you're wrong RP, because for years, I didn't torque it down and I only used the wrench exactly the way you stated. I just did the "tighten by hand and then a quarter turn of the wrench" to finish it. I do torque it down now using a filter socket. It really doesn't tighten it down that much more, but it does stay on
) Don't over tighten your filter thought. 2g fitler housings bend really easy and then it is impossible to get them to seal and not leak oil. Then put the seal in, align it and put the stud back in and torque it down. PM me if you need the seal though I'm sure I still have one.
Well, I ended up getting a new filter (regular fram this time) and put it on and filled it up with oil. I started it up and everything was cool. No probs since then.
) but also my oil filter came loose and my oil dropped. Only thing is, when I got a new filter... it still loosened up Our Oil housings have a 2 piece design with a gasket in the middle... mine blew. Well it wasn't the first... then the oil filter came loose 2 more times and the gasket blew as well both times....
