anyone care to help out a newbie?
Tyknowlden
33
Jan 8, 2010
grand junction, Colorado
i recently posted my problem i have a 6 bolt swap but no starting. i went through alot of the suggestions and still nothing i recently rewired the ecu the 4 pins for the injectors but nothing i did notice that whenever i press my brake pedal my dash lights come on but without pressing the brake the lights dont work could this be the ecu? im 90% sure i wired it correctly i was reading that the cps could cause it not to start? i have a black top one how do i check if its in sync? and do the black tops work for the 6 bolt swap? also can anyone post what the fuel relay and mpi looks like? i cant tell for sure if i even have those in my car, i have spark and compression i think im getting fuel i dont know for sure how to check. any help is greatly aprreciated!
hmmm thank you ill check my ecu tom im pretty sure it ended up looking like that i just changed the 4 pins they say to change with a 6 bolt swap do i need to cut and add any wires? i have 2 sets of plugs coming off the cps but where do i hook them up? one is a square one is a triangle 3 wire do i plug these in or add them to other plugs? and about my dash lights is it possible i have a 1g ecu? or just wired it wrong? all help is greatly appreciated!
There's a triangle plug that goes to the coil pack and one that would be unused for the crank angle sensor. Check the 2g engine bay wiring diagram to check which one is which.
