any one here in arkansas/oklahoma area willing to help a fellow DSMer
l3igl3ang
539
Aug 10, 2005
ft smith, Arkansas
i live in the midwest Ark Ok area 72904 and would be willing to drive to meet some exprincerd DSM'ers to help me with my 96 AWD talon. Its missing and sputtering and i can't figer out the problem :mad: i changed both pulg and wires with no luck.
I had a N/T talon about 4-5 years ago that did the same dam thing as this ones doing on the sputtering part and i never figerd it out before it got wrecked.
i'm in midwest city, oklahoma, i have a 97 awd tsi talon
here's a crazy question, my car runs great but for some weird reason i cant full throttle it, when i do it sputters, no boost leak spark plugs are good, i am missing my catalyc converter and my rear o2 sensor, my check engine light is on but for my speedometer not working and my rear o2, also are u suppose to hear your stock fuel pump whine like an aftermarket one, i think the guy that had it before me did an engine swap for a newer 4g63t motor, but i'm not sure if he forgot to take out the fuel pump or what, also i run 91 octane, could that be the problem, should i run 93, it's like i can hit 10 pounds but anything over and it sputters, other than that it runs like new and the body is in almost mint condition...
My car did the same thing and i found out i broke a valve in cylinder 1. Pull wires out 1 at a time and try to start the vehicle. If it will still start and feel the same with a certain wire out then thats the cylinder your having a problem with. If that is the problem.
