Any experience on ebay external gate/ Punishment o2 housings?
"Tail's website"? Sounds dirty :) .
I did this for some time. It works well. But with TiAL's suggested plumbing, you don't get that quick spool like running a ball and spring valve off the lower port alone, or with an internal gate, it's only port. It holds well to a certain point where the spring wil let the valve blow open. So not but so much boost can be used until a bigger spring is neccesary.
I wanted the gate to see no boost until the threshold I chose (like a a traditional mbc install) for that quick spool. And while I was at it I wanted not to swap in another spring again. My way above is not the cheapest. But it is VERY good at not spiking. Which I was having a problem using a stronger spring and one MBC on just the lower port. Just adding my experience. . . Someone elses setup may act very difference.
Also, my 5psi spring from the ebay gate couild hold up to 20-21psi with the mbc working at just the lower port. It cracked upen after that with my holset.
