Ludachris
Founder & Zookeeper
- 8,879
- 4,725
- Nov 12, 2001
Newcastle,
California
So the door handle was replaced on my 2g before I bought the car at some point. I have the key for it, but the problem is this - if I lock the door before getting out of the car and try to unlock it with the key on the driver side and open the door the alarm goes off. I can close the door and turn the key to re-lock it and it turns off the alarm. And then when I turn the key yet again to unlock it, it will disarm when I open the door. WTF?
I also noticed that the passenger door lock has a broken piece of plastic inside the door that prevents the auto door locks from working. If you lock the door from the passenger side, it locks that door only and doesn't arm the system. Yet, it will disarm if you unlock it with the key on the passenger side. I located the white plastic lever inside the door that is missing, as I can see it on the driver side.
I just want to be able to unlock and disarm the system with the key on the driver side. Seriously, it shouldn't be this difficult. If it arms when I lock it from the inside shouldn't it disarm when unlocking from the outside using the key?
