AMS GT37R (PT67R dbb) T3 or T4 hotside?
A t4 .96 is going to spool alot later than the t3.63 Infact it will spool later than the t3 .82 as well.
I think you would need something like a t4 .70 turbine housing.
-Remy
Remy, you are correct that an open tang .96 T4 will spool incredibly slowly, but I was referring to a divided housing .96 T4. Lots of evo guys are switching to divided hotsides and seeing excellent results over open turbine housings. If you check out the thread below you will see testimonials of guys who switched from open tang 35r and 37r turbos to divided t4 hotside 37r and 4088r turbos that experienced much better response and driveablity with the larger divided hotside.
http://forums.evolutionm.net/showthread.php?t=294440&highlight=4088
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
