turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
Okay, I've said that I'm not that well versed in alcohol injection so here's what i observed today.
I made multiple passes on gas alone to get my AFR's right on target through the entire band from 3-8k RPM. I was seeing ~2* of timing being pulled after modifying my timing curve after seeing the first signs of detonation. After everything was smoothed out and dialed in i was able to pull all the way to redline with only a trace of knock here and there.
Here's where it gets weird. I turned the alky back on to see if those few degrees would disappear on alcohol... To my surprise i ended up with more knock on the alcohol than i did on just plain pump gas. *scratches head while dumb-founded*
Now the only thing i can think of is that when my AFR's were deep into the 10's and 9's it was knocking from too much fuel ( I'm guessing because it went away when i leaned it out)
But my question is can the alcohol be richening it up enough to knock from richness or is there something else happening? I pulled several logs (knock isn't loggable though) and am only seeing a max of twenty degrees cooler air while running alky. (60* on it compared to 80 off alky..this is in teh end of 4th after a full 3rd-4th pull) So do i not have enough, too much or is there something else i should look into?
Also my knock sensor goes crazy on gear shifts, and even more so on alky. I've desensitized the knock monitor to a good point and don't want to make it any less sensitive that it is now, but i want to get to the bottom of this. Especially if I'm going to pull the test of running no FMIC on alky injection alone for cooling ( my other thread)
Do i need to tune it to the 11.5 on the alcohol, or should i be fine at 11.5 on gas and then adding the alky? ...please, only people with FIRST HAND experience only on this one for replies
