Aftermarket radio plug to run gauge lights
2slow4now
1,311
42
Nov 20, 2008
Hilton head, South Carolina
I was putting in my aftermarket radio and had gotten an adapter plug so I didn't have to cut the factory harness. The plug came with the dimming wires which can't be used on my aftermarket radio. The instructions said to just tape them off and leave them unhooked. I was also changing my aftermarket gauge lights to leds. I never liked what I did to wire them up in the first place (wired into the cigarette lighter light) Yep guilty and lazy.
Its a scosche plug and has the normal radio wiring.
yellow- 12v constant for memory
red- 12v switched to power up the radio
blue- power antenna/amp trigger
black- ground
4 pairs of wires for the speakers
and
orange- Illumination/dimmer
orange/white stripe- ?? no label ?
Thats the two I used to run my gauge lights. I used the solid orange as the power feed + and the orange/white stripe as the neutral -
The gauges dim right along with the dash lights perfectly.
I figured the stock lighting on the stock stereo had to pull more juice then a few leds for the gauges. Does anyone see a problem with doing this?
I think doing it this way would be alot better than having to cut insulation off the dimmer switch wiring and soldering the connection there besides the wiring goes back to the dimmer switch anyways. My thoughts on it are the same reason everyone buys a radio plug adapter to install an aftermarket one. To not comprimise the wiring. I just don't like cutting the factory harness unless I have to.
I don't know how many regular light bulbs are in the radio but I figured it was more than 3 depending on what radio you have. Thanks Calan, I knew they pulled alot less but didn't know how much.
  • Wanted 2g WTB - 2G Cluster
    Looking for a donor 2G cluster for a project.
    • rwmagee90
  • For sale 1g 1g FWD 3speed design scattershield
    1g fwd shield
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $35 each. Message 702-741-6987.
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale Cts-v calipers+rotors+adapters
    1g/2g CTS-V calipers cobra 12.99” and ctsv adapters, $650 plus shipping&pp fees text me if you...
    • Fully built dsm
