2G After market Rear O2 sensor location
normally the rear o2 sensor is after the cat. i assume you still have the cat since your in cali. So as far i i know, it would be better to get a bung welded on the down pipe.
If there's no cat and you still run a factory front o2, it will be fine. What you don't want is to be simulating the front o2 from that far back.
No cat. (I know a smog ninja) 3" catless from O2 housing back to a Agency power exhaust. It just seems like it's too far back for an accurate reading
screw smog. all it takes to figure out its a bunch of BS, is 5mins on google and a tiny bit of common sense. Co2 only makes up 0.04% of the atmosphere. Its not a problem. any lower and plants wouldn't grow for shit.
just make sure you don't have any leaks before the sensor.
here is a quote from innovate motorsports
Positioning the sensor too close to the exhaust ports can expose it to high exhaust gas temperature (EGT) as well as over-cooling from the high-velocity exhaust gas flowing over the sensor. Likewise, if an engine runs excessively rich, an oxygen sensor that’s positioned farther downstream is less prone to fouling. Although these extreme conditions aren’t a concern in most street applications, placing the sensor farther down the exhaust tract is rarely detrimental.
Three feet from the head is recommended for wideband sensors.
Then I'll be moving it ASAP. Thanks for the input everybody! Slowly getting it dialed in for a WOT tune. It's boosted to 10psi with no hiccups so far but don't want to push it harder than that for now. I'll update soon!
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
