Aeromotive- fuel pressure regulator Install
eclipse90gsxt
438
Feb 11, 2003
Rochester, New York
Ok I am buying the Aeromotive- fuel pressure regulator from SBR, and they have the fuel line also for sale. I know I need that line, my question is will that bolt to my 1G fuel line or do I need the Billet adapters that DSM motorsports sells?
Also do I just buy a 6 an fitting that has a hose adpater on it for the return line?
Any help would be awsome.
Patrick
if they sell a kit with everything buy the kit. You will need the unit along with two 6-an to 6-an adapters with O-rings and a end cap with O-ring. Also you will need an adapter to the fuel rail that goes to a 6-an then you will need a 6- an to 45 degree angle that has a hose connector on it. as well as two other twist lock hose connecters. Get a kit for your car if you can. Its pricey but if you buy those parts seperate youll find out why.
