Fuel Pressure Regulator, reliable?
I see it going for $225 + shipping on ebay. if this is the case, just go with whats proven with DSMs, the Aeromotive setup, comes with gauge and fittings and lines for about the same price.
I found this exact item for less than $100 in a local shop. Thought about buying it.
Oh... Okay. I didn't understand what that was but thanks for clearing it up.
1:1 ratio means that for every 1 psi increase in boost, the fuel pressure regulator (FPR) bumps up the fuel pressure by 1 psi.
So if your base fuel pressure is set at 43psi, then at 10 psi of boost the FPR increases fuel pressure to 53. At 20 psi of boost, the FPR increases fuel pressure to 63.
Thank you for clearing that up, I wasn't understanding exactly how that worked.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
