2G AEM EMS no spark 1+4
BLACKCARBON
95
4
May 13, 2009
NY, New York
my car has been sitting for a few months so with the weather not gettin any better i decide to start it about 2 weeks ago and all the car did was crank.
stat sync comes on,regulator reads 38psi so theres fuel in the rail.
manually setup triggers through throttle and im only gettin spark on 2+3.
-replaced ignitor,plugs,cop,checked wiring from ecu-ptu-coils
aem found nothing wrong with my ecu,just waiting on getting it back.
car ran fine before
what else would cause no spark on 1+4
mpi relay?fuses?
i also noticed that with "key on" if i move the box slightly i hear a on\off clicking sound
is the relay goin bad?
setup:
97 gsx
6-bolt
2g head,1g black cas
cop coils
thanks for any help
As far as the clicking sound, i have heard that on all of my turbo dsm's that i have owned..Have you disconnected the battery for about five min and connected it again then tried? If it does start there is somethin goin on with the ecu most likely. (Thats whats going on with mine right now)
according to aem there are no moving parts inside the box,so the sounds cant be coming from the ecu.
i left car overnight with battery disconnected to make sure and still clicks
tested both fuel pump/mfi relay
fuel pump- 70 ohms
mfi-67 ohms
good or bad?
is it possible the cas is bad even though stat sync comes on.
what else would control spark?
i traced the blue/red wire(coil 1) to the speed detection connector(blue plug by the firewall).this is where it changes color to the black/white wire that goes into pin 8 of the ignitor. one of the wires broke off at the blue plug.
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
