2G no spark 1 and 4
myboostedtalon
Nov 7, 2010
Troy, Missouri
I'm not getting any spark on coil 1 and 4 I've replaced the coil checked out the power transitor on another car as well as the ecu on another car. Is there a jumper write I can make straight from the
Ecu to the coil? The car is a 95 tsi awd
I did find one spot on the blue w/red wire which is the middle wire on the engine side of the plug to.the cas that looked like it was probed with something like a meter lead it kind of raised a red flag but wasn't for sure if that would cause an issue on just the 1 and 4 side
I bet you the cas broke. The brittle plastic tab broke off.
