2G No spark in 1 and 4
justinhill98gst
190
Sep 1, 2007
White bEAR laKE, Minnesota
Long story short I degreased my engine and it would not start. It turned out to be a bad crank angle sensor, now the car is running but is not get spark on 1 and 4 so far I changed out coil packs and power transistor. The car would run right then its like 1 and 4 just turns off. any input guys? btw its for a 1998 gst
Also it started out it would drive normal then just it would cut out now it will not get spark at all in 1 and 4
Check the ground wire from ecu, put in a 1g CAS, check terminal on transitor plug to coil pack for resistence, Check resistor plug to ecu make you get the same resistence on all 4. Check on ECU pin 1,2 & 14,15 injectors with pin 13 & 26 ground make sure there is the same resistence.. Try That
