ACT 2900: Old style vs new?
MindBlowin03
919
713
Apr 11, 2002
Jessup, Pennsylvania
Im not at all interested in the disks so Im just asking about the pressure plates. I know the newer style pressure plates have the 'strengthening humps' in the fingers. Here are my questions...
1) Were the humps an answer to broken fingers? Upon searching I have seen broken fingers with both old and new style fingers.
2) Does anyone know if the pedal pressure was changed/lightened with this revision?
Old style
New style
The main reason I ask these questions is because I am searching for a 2900 pressure plate and I dont know if I should stay away from an old style or if it really even matters.
I've had both and the 2900 is a little bit lighter. After a little while in bumper to bumper traffic, you won't be able to tell if it's lighter or not cause they all make your leg tired! I actually have the new 2900 in there right now. I've had the 3200 also, and it felt about the same as the 2900.
I'm running a 2600, but I'm in the market for a 2900. I currently have an old style 2600 with the thick fiingers. The one thing I have noticed is they have a tendency to have centrifugal assist. Meaning as the RPM's come up the fingers come out, clamping the disc tighter. This also eats up some of your release travel, leading to release problems. It gets worse as the disc wears.
This was with a new in box (but old) 2600pp, ACT 4 puck and new ACT streetlite.
Off topic, but I just got my GGSX ripping, and I re-experienced launchin on a street disc, and it's so much easier than a 4/6 puck. I want to try the old school shep, 3200 street disc combo.
you can see it in this picture. By 7500 it's causing problems. I have worked around it, but it still sucks. The cheap china XTD clutches worked better.
That's a pretty cool log. Let me see if I'm looking at it right:
Shift out of 1st at a little over 9000 rpm
out of 2nd at about 9000 rpm
out of 3rd at about 8500 rpm
Forward accelerations of about 0.4 g or a little less - Oops, more like 40 ft/sec^2 in 1st and 2nd gear?
Shifts taking about half a second
Is there anything wrong in there? I can't see anything wrong.
Oh yeah, then over to the right from about 12 seconds on, where your rpm's have come down, the TO bearing is riding where it should be.
Cool! I mean, bummer!
Old style 2600 with the thick fingers - would that be like the one in this picture?
This is a screen shot from a Tom's Turbo Garage video, the one where he is replacing his ~5 year old ACT 2600 with a new ACT twin disk.
I shift at 9600, 9000, 8600. Look at the purple clutch trace. See how it rises with rpm. That is throwout bearing position.
I think i might've asked you this before but what is done to your transmission? And how is your clutch pedal assembly holding up with the 2600?
