yoyo13131
- 75
- 0
- Feb 5, 2010
Santa Clara,
California
I have a early 1993 Eclipse 2.0 GS with an R-12 system.
My ultimate goal is to find out why my compressor isn't getting 12 volts...
Compressor clutch does work, resistance is perfect. Compressor ground is good.
Just replaced the Accumulator and replaced o-rings on compressor. Opened up the ACCU (Air Conditioning Control Unit) and don't see ANY sort of burning or leaking capacitors. AC Switch works, tested with volt-meter. Don't know if Dual Pressure switch is working so I jumped it while testing. Opened up my ECU also and its flawless.
Is it possible for the magnetic clutch relay to be half working? because both my clutch relay and fan realy both don't have continuity on terminal 2 and 4 and give a reading of "70 ohms"
I had it charged yesterday with R-12 but my compressor clutch wasn't engaging because its not getting 12 volts...
any ideas?
any ideas?
