A simple question about gauges
Hideki
815
4
Apr 23, 2006
West Hills, California
I've got a gauge pod for two gauges, I was planning for boost & and EGT gauge. The only problem is that I've decided to use the Zeitronix wideband for EGT and so now I've got an empty gauge pod... My question is, what gauge should I get? :D
if you are going to spend the money get the wide band you'll be better off in the end
Did you even read the post?
I would suggest an Oil Pressure gauge, the stock one isn't accurate to say the least. Oh and you'll like the logging of a/f, egt, and boost(if you get the map sensor) with the zeitronix.
