1G A little help with adding sensors to ECMLink
pearl4gtsi
223
7
Jul 17, 2004
yonkers, New York
Hey all, its been a long time since I've posted anything and am in need of some clarification on wiring in some sensors as I'm currently working on my harness.
I am going to wire in a wideband O2 and a fuel pressure sensor. I am not running the factory O2 and will use NBsim. So that leaves the front O2 pin 4 open. I also believe I can use pin 15 which is for EGT temp, which is only on CA cars.
1) Now I assume I can use either input for either sensor, correct? Because I feel like I've read somewhere that the factory O2 input has trouble with some widebands? Or am I mistaken?
Would it make sense to just use the O2 input for the WBO2 to keep things simple and then pin 15 for the fuel pressure?
2) The factory O2 wiring has both power and ground obviously. Is the power a 5v source? Should I use that power and ground for the fuel pressure sensor since I can get the power for the wideband from the interior using the Innovate gauge?
3) Where in the engine compartment can I find a switched 12v source? I believe I need this for a flex fuel sensor and I'd also need this for wanting to run a DRL for the front lenses.... using led switchbacks in the front lenses for a DRL and turn signals.
Any help and clarification will be much appreciated!!
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
