2G wideband wiring help
ncarson91
5+ Year Contributor
138
19
Jan 2, 2021
north olmsted, Ohio
ok so new to this got everything hooked up for wideband now im wiring it directly into the ecu and the wire is pin 75 which i cut stripped out now the question is. DO i have to connect the borth parts where snipped and splice in the wire from the wideband? or do i just connect the wideband to the wire connector part that plugs into ecu?
Assuming you are trying to feed an analog (0-5v) wideband signal into the ECU so ECMLink can read it you only need to attach the wire to the ECU side and not connect both ends of the original wire you cut.
Does that make sense to you?
Then configure ECMLink for it.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
