snowborder714
Moderator
- 16,189
- 471
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
So, I have two questions. First of all, I pulled off my bov the other day to clean it. I looked into the uicp where it was bolted on and saw this.
Is that normal? If so, what is it from? I know the uicp is pretty crappy so I'm not sure if it's a really bad weld job or something else. Also, could that be hindering performance? And if it isn't normal, how can I fix it?
Second question deals with motor mounts. I have Prothane motor mounts (I think) in 2 out of 4 mounts. This one is the drivers side mount.
Should there be a space between the lip of the bushing and the metal of the motor mount? What might have caused it and if it's bad, how can I fix it?
Thanks!
Thanks!
which happens often, there is absolutely no good reason not to cover it. Also in case if you didn't get my point earlier, change the other 2 stock mounts to poly mounts.
