codeofdastreets
- 505
- 3
- Sep 25, 2008
dunedin,
Florida
I been doing alot of reserch but really cant find the answers im looking for about priming the oil pump on my new built.
The motor is on the motor stand and im waiting for the rest of the parts to finsh it up ( oil pan, cams, cam gears, oil pick up).. I recently installed the head on the motor. Now here is the questions. I want to assemble the front case and oil pump and mount it on the block to get this done, but the motor will be sitting for about a month before I can prime it for oil because im waiting to get some money for the rest of the parts I need. For the time the motor will be sitting would vaseline be fine in the pump?? or should I use sometype of greace? and if so what type exactly?
Ok now a Month passes and all thats left is timing (still on the stand). Id like to prime the pump at this point ( just is the long block no turbo, 4 1/2 qts of oil in the motor, oil feed from oph is plugged, drain on oil pan has a 10an cap to just insure no oil spills, and oil feed on the head is open to make sure im getting oil since this is the highest point of the motor and last to recive oil)..I prime the pump with drill clockwise and get oil to the head.Then after do timing and drop in the motor no trans since I need to get a clutch and want to get a fresh rebuild on my trans.
Another say month or more passes, I recieve my clutch and rebuilt trans I install it and im ready to fire the motor up. ( month or two passes since I originally primed the pump, with oil still in the pan) Should I turn the motor over again with mpi fuse out to get oil back up to the head to make sure everything is good?? Then start it up???
