green_bread
- 52
- 2
- Sep 20, 2005
Columbia,
Missouri
Whats goin on everyone? I am taking on a little "project" with my data logger and Im looking for info from anyone who might have done something similar before. Heres whats going on:
I have a 1g with ABS. I am sure you all know that when you leave the data cable plugged in to the diagnostic port, it disables the ABS. I was going to do the switch mod, but i wanted to make sure that I had the info right before I went to cutting wires. The information I have collected for the mod came from http://www.hywell.org/absmod.html. On this page, the guy is talking about cutting the wire that goes from pin 10 on the dignostic port to the ABS control unit and wiring a switch in line.
Here is a picture of where he tapped it in:
The switch I have is a 3 prong guy. The leads are for power, load, and ground. I took a multimeter to leads 1 and 2(power and load, pin 3 is ground) and found that continuity is broken between these contacts when the switch is off. So, for wiring the switch, I would just cut the wire that goes from pin 10 to the ABS control unit and run one wire to pin 1 on the switch and another wire from pin 2 back to the other end of the cut wire, right? Then all I would have to do is turn the car on, then turn the switch on, correct? No more disabled ABS?
This is the picture I REALLY had a question about though:
What is the extra red wire that goes from the back of the data cable connector to the fuse panel? Is that for power to the switch or something?
Ok, so that was the first thing... the other thing I was trying to achieve is being able to charge the Palm in car. I actually took a Dremel to the coin tray and the cradle for the Palm and made a custom mount for the Palm right in the center console. I was planning on grabbing power from the cigarette lighter, but I ran in to a problem. The cars power is 12v DC while the Palm charges at 6v DC. (Also should state that Im using a Palm Vx..-they have a weird plug that attaches to the back of the serial connector on the cradle to plug the power source in to charge the Palm.) So, I thought I would buy one of those car chargers that you plug in to the cigarette lighter and splice the Palm connector to it(plus, it has an output of 6v). Second problem!! The car charger only has 2 wires. The wire that goes from the wall plug to the connector on for the Palm has 5 wires in it. So, Im just wondering if anyone else has tried this and if they have any ideas for a better way to do this???
Thanks for any help!
ADAM
ADAM
