Resolved 99 GS to GST
Ventus2geclipse
Sep 28, 2021
Port St. Lucie, Florida
I have a GS eclipse that's been sitting for a while and the last time it ran the transmission(automatic) blew up and only recently I decided to fix it up and bring it back to life. I have a standard GS-T tranny should i also get the GST 4g63? please let me know if anyone has any tips to get it up and running.
please don't tell me to get a gst or a gsx
Sell it and get a GST. Im sorry but that this point that's the easiest route. Otherwise, source another used auto trans and call it a day
Here is how I would answer this question. Do you have the skill set or funds to fabricate mounts for an engine and bolt it into any car. That is essentially what you're doing. The fact that the sheet metal is the same is irrelevant. The only known constant is the frame rails are exactlly the same width but that's not really helpful. In addition you will need to source or fabricate a harness,ecu, axles and Misc bracketry.
That is what it takes to put a 4g63 into a 420a car. If you answered no to the above then the other posted advice remains. Source another 420a compatible transmission.
