2G 98 Eclipse max mph is 20 30 mph
Iceman8079
51
Mar 1, 2023
Walton, Indiana
Bought 98 eclipse with bigger turbo and other upgrades replaced map sensor as well. Still has factory cat. No check engine lights or codes to reset. Was this king maybe cats r clogged only has 80xxx actual miles.
I would have to say to pull your air filter out to make sure that you dont have a nest in it, and check the car for a clogged catalytic converter then, is this car an auto? if it is, is it shifting properly?
I will check today. Car is a auto had been sitting for 3yrs before I purchased it. Guy explained that it had this issue is why he parked it.
If the car is an automatic your throttle position sensor isnt plugged in, that's why the trans wont shift. Or youre having issues with the throttle position sensor calibrations.
Or your trans is blown
Or the transmission control unit is bad. (Tcu is the term, transmission computer is what it is)
Usually the throttle position sensor plug isnt secured all the way into the throttle position sensor, and you just have to plug it in and zip tie it into position
If the throttle position sensor has been replaced then you need to calibrate it using a voltmeter. Its a pain in the ass to do, so hopefully you havent touched it, because it involves using a volt meter and rotating the throttle position sensor after you loosen the screws that hold it to the throttle body. If you dont want to do all that then the best thing to do is to put a used non tampered with stock throttle body assembly with the sensor back on the car
Pull the intake tube from the front of the turbo inlet and spin the blades by hand and move it up and down to check for noise, binding, or play.
