Dsm2Nv
- 183
- 7
- Dec 27, 2007
toronto,
ON, Canada
I have broke in my 6 bolt swap last summer and this summer i am installing a new turbo along with some new parts heres some pictures of the build.
This is what i had done to the engine.
Disassemble Engine and inspectio
Engine head rebuild and resurface
Bore/hone cylinders walls plus wash and replace frost plugs
Resurface block deck
Balance rotating assembly
Align hone main bore
Micro polish crankshaft
Assemble bottom end/set ring gaps
Assemble long block assembly
Parts Used For This Build.
Ross Racing forged pistons 9.1 comp
Eagle H-Beam Connecting Rods
Arp Main studs
Topline Oil Pump Assembly
Topline Waterpump
Topline complete gasket kit
Mitsu Timming belt
Mitsu Hydrulic Tensioner
Mitsu Idler and Tensioner pulleys
brian crower springs,valves,retainers
Mitsu 4 layer MLS headgakset
Arp Head studs
ACL Race Main Bearing set:
ACL Race Rod Bearing set:
Topline revised lifters
40mm tial wastegate
vict performance 02 housing
vict performance external dump
greddy timming belt
aem wideband
stewart warner boost gauge
hks full exhaust
1000cc injectors
Heres some pics of the engine build will upload pics of other stuff when received.
After engine build paintjob and just about everything else done to it.
Arp Main studs
Topline Waterpump
Mitsu Timming belt
Arp Head studs
40mm tial wastegate
greddy timming belt
aem wideband
hks full exhaust
1000cc injectors
