95' GS-T Turbo Swap on 95' GS? Is it possible?
2G420AAA
May 24, 2014
East Bend, North Carolina
Hey guys so I just bought a 1995 Eclipse GS-T w/ a spun rod bearing for a sweet $800.00, low milage great body, the only thing wrong with it is the rod bearing. Well I'm not really looking into fixing it, just upgrading my 1995 Eclipse GS with some of the odds and ends and then making some money off the GS-T. Well I really got to thinking about it, I'm curious to see if you kept just the turbo and a few of the other parts , could I just buy a manifold and whatever else and turbo my car? :idontknow:
..and yes, I know the motors are completely different and practically zero parts are interchangeable. I just came here to see what parts I could use to help turbo my GS. I'm just looking to save some money.
Thanks guys. -Josh:dsm:
There is really nothing at all from that engine bay that you can use on your car. The interior, suspension and body yes, engine nothing.
Uuhh your better off selling your gs and using that money to fix the GST as their worth more money and it opens the door for more possiblities.
to turbo your gs is not at all easy, first turbo injectors are low impedance and your non turbo are high impedance injectors let a lone your engine wont take the added power of the turbo very long even if you do all the other work to make it possible.
I dont mean to be rude its just very impractical in most aspects.
and I would so do that, the only thing keeping me from doing so is honestly the cosmetics of my GS. I really don't want to have to go through the trouble of painting the GS-T. I was just thinking it'd be easier to turbo my GS rather than tear out the motor to my GS-T. I mean I don't know if the rod bearing is the only thing thats wrong with it tbh, the oil looks like metallic paint man.
Unless the turbo is a genuine MHI TDO5H or bigger unit, don't waste your time.
Also there is a good chance you may need to rebuild the turbo after the rod massacre.
Umm what if it is..? Is that a good thing? LOL. Sorry I'm new to the whole turbo game. Just got the GS-T like last week.
Yeah, but the cosmetics on the GS are sooo much better. I don't want to have to go through the trouble of painting the GS-T and pulling out the motor. I'd rather just turbo the gs. I've already took the struts and springs off the GS-T (it had Takico struts and springs I didn't know aboutROFL) I just think the GS would turn out a much easier and cleaner build. For the GS-T I would have to buy a front and rear bumper because the ones on it now are hideous, also a paint job is really necessary, the rod bearing and whatever else is damaged (the oil looks like metallic paint.) So all in all, the GS is looking like a pretty good option at the moment..
oh, and I don't have an unlimited supply of money like some of you guys. I need to go the cheaper option as well. Thanks
Its easier to fix the GST, you'd have to put 3k + into your gs to make the turbo swap successful. You could alway sell both and find a clean gst or gsx, i'd say do the evo swap on your gs but that takes a lot of knowledge and experience.
by the sounds of how your oil looks in the gst more then likely all your engine bearing are pootched and there could be damage to the crank as well.
thats actually not a bad idea to sell both and find a nice gsx or gst.. I'd say I could probably get $1,000-1,400 for the GS-T.. and probably about $3,000 for the GS. $4,000 could get me a nice GS-T. Thanks for presenting the options to me man, you've really got me thinking now. LOL
The stock 2g dsm T25 turbo is made by garret, and it's really not worth much.
but according to your image you got the better Mitsubishi made turbo.
Write down the numbers on the side of the turbo,
if you want to know which type of MHI turbine wheel it has. the numbers you're looking for will start with 49178- the next 5 digits will tell you what kind of MHI turbo it is.
[see reference chart below]
14b:
49178-01010
49178-01030
49178-01400
49178-01410
Small 16G:
49178-01520
49178-05200
Big 16G:
49178-01420
Evo I Big 16G:
49178-01450
Evo II Big 16G:
49178-01460
Evo III Big 16G:
49178-01470
If you want to turbo your gs I think it would be wise to just do a project build on the gst.
Or save up your money and do the evo conversion on the gs.
The 420A will needs a lot more money to make it at the stock level of any 4G63 turbo motor.
tuning software, a turbo, bigger injectors, a larger exhaust system, upgraded clutch,and the
engine/drive-train will need to be in perfect health to handle all this.
all this could be overcome by doing an engine re-build, a little paint/body work on a 2g gst
[assuming thats all it needs]
Do you have any pics of the damage on the gst?
14b:
49178-01010
49178-01030
49178-01400
49178-01410
Small 16G:
49178-01520
49178-05200
Big 16G:
49178-01420
Evo I Big 16G:
49178-01450
Evo II Big 16G:
49178-01460
Evo III Big 16G:
49178-01470
Nah, I haven't even dropped the oil pan yet, I can get pics of the oil if you'd like haha. Will that turbo alone work on my Eclipse GS though? I just don't want to get in over my head on the GS-T. I have to sell one of the cars to get money to build the one I don't sell. I don't care about which one will be worth more in the end or anything, I just want a good solid, cost effective car build @mitsubishikid
14b:
49178-01010
49178-01030
49178-01400
49178-01410
Small 16G:
49178-01520
49178-05200
Big 16G:
49178-01420
Evo I Big 16G:
49178-01450
Evo II Big 16G:
49178-01460
Evo III Big 16G:
49178-01470
It says 49178-01470.. meaning its the Evo III Big 16g? Can I use this on my GS?
Nice you got one of the best 4G63T street turbos.
As far as bolting a turbo up to a 420A while it can be done I Don't think they make a manifold to bolt a dsm turbo directly to 420a.
You'd need to ether make a custom exhaust manifold, or buy one of the t3 flanged ones and weld together a 4G63T exhaust adapter together.
which equals more money you wont spend if you rebuild the gst.
me personally I feel the gst is gonna cost less and perform better. More after-market support is available for the 4G63T then the 420a.
and since it's a more common power plant some parts will be cheaper too.
I get where you are coming from on the GS-T man I really do, you'd just have to see it with your own eyes and then you might understand me a little better. Maybe I'll upload a lot of pics comparing the two tomorrow. Oh yeah, so basically the turbo is the only thing I can steal from the GS-T? intercooler? injectors? ecu? air intake? anything? @mitsubishikid
I would suggest reading some of the build threads with guys sticking a turbo in their GS. The engine is significantly weaker than the 4g63, which means to make as much power as a stock 4g63, you need to dump a bunch of labor/money into the car (on top of being much less reliable). Many other members have made similar comments, but I think you should do some reading on the subject to really get a firm understanding of what you would be getting yourself into.
If the damage on the GST is not bad, there is nothing stopping you from swapping your GS exterior to the GST. Before ruling out fixing the GST, why not drop the pan, pull the head, and see what kind of internal damage there is - you may be surprised.
The third option is always 2 dsms are better than 1 :).
Haha, I feel you on that note. and thats probably exactly what I'll do, see how bad the damage is and go from there
if you turbo the 420A there is no guarantee it wont blowup after 1 to 3 light duty pulls.
and then you will have 2 blown dsms.
I'm not trying to avert you from your turbo 420a project, just giving you an idea whats at stake.
I think you should pull the valve cover, and the oil pan, off the gst 4G63T, and inspect the motor.
Right I'll probably do that tomorrow if I have the time.. I know this is probably going to make me sound like a complete retard but is it possible for me to just swap the exterior? Haha
:) here is something that nobody has also told you. You also have to run some type of programable ecu to control your turbo gs, so you have to learn how to read the fuel maps so you can properly tune it. You also have to modify the frame rails in the engine bay to mount the 4g63. So I guarantee you that it will cost SOO MUCH more to turbo the gs . either you spend a bunch of money to turbo the gs and get 4g63 stock hp all the while of not having a reliable car or keep the drivetrain from the Gst than find yourself a clean turbo shell. you really have to know what your doing in order to have a RELIABLE, fully working turbo gs. Good luck, another piece of advice is to READ all you can about this process before you do ANYTHING to your cars.
I dont think he was looking at doing a 4g63 swap, just adding a turbo + supporting mods on a 420a.
2g42, any part of the exterior that can be removed from the GS will fit on the GST, which is why we were asking what the extent of the exterior damage was.
There's no real exterior damage it's just the paints is pretty bad.. I wouldn't even be on this thread if the GS-T had a nice red paint job. I just want to avoid having to paint a car, LOL
You could always just do a roll on rustoleum paint job. If done right than it will turn out looking real good, and cost you 150 bucks.
