93 tsi 6 bolt swap
lzertrbo
125
Jun 22, 2009
spanish fork, Utah
ok so i have had tons of electrical issues in my laser rs. and so i am buying a tsi that spun a bearing, it doesnt have an engine and mine is good so i am going to need help on the process can some one give me a list of what i should do first when pulling the motor, i will post pics as soon as the tsi gets here
Yea there's no electrical work to do when swapping metal blocks. We're not talking about swapping sensors. Just keep your original head from the 1993 car, with all the sensors/gaskets/electrical still in place. Blocks are a direct swap.
There could be several reasons for the low compression. Was the motor warm and was the upper intercooler pipe removed with the TB butterfly wideopen when the test was done. It could be slightly bent or slightly burnt valves. Or the cams could be out of time. . . Be sure. You may be pulling apart a perfectly fine 6bolt shortblock. This is why I recommend a leakdown test. You can hear where the pressure is escaping.
but with keeping the 93 head the holes for the studs or head bolts will need to be bored out from 11mm to 12mm
