'92 TSI Complete Rebuild From Firewall Forward - Part 23
Calan
DSM Wiseman
7,250
400
Jan 16, 2007
OKC, Oklahoma
Ok...where was I?
When I started working on the rear of the car, it was pretty apparent that the fasteners were in even worse shape than the ones on the front of the car. After some close inspection, it turned out that most of it was just surface rust and years of road grime. So rather than spend lots of $$ on new suspension bolts, I decided to media blast them all and started thinking about ways to protect them.
View attachment 2068 View attachment 2069
After thinking on it a few days, I decided to give Caswell''s black oxide kit a try. It is an easy process that uses no heat or dangerous chemicals, meets mil-spec, and is cheap. (And I couldn't find anyone local that does plating on a bucket of bolts).
Note: I've never been fond of blackened bolts from hardware stores that seem to rust the minute they leave the store, but Caswell has some good stuff and I figured it wouldn't hurt to try it.
The blackening process was about as easy as it gets; mix up the solution in a bowl, and dip the parts for 3 minutes or so. The hardest part was bending a crapload of paper clips and coat hangers, and figuring out where to hang them to dry after they were dipped in the sealer. LOL
What I ended up doing was hanging the bolts and some of the nuts/washers in a cardboard box, and using a coat hanger clamped in a vice for the rest.
View attachment 2070 View attachment 2073
Note: Caswell ships the basic kit with an oil-based sealer that works very well, but it takes about 2 days to dry. And even then, the bolts remain a bit oily to the touch. It worked fine for suspension bolts, but for other types of fasteners it would probably be best to spend the extra money on their faster-drying acrylic sealer.
For the rear diff cover bolts, brake line clamp bolts, and a few others... I clear-coated them after blasting rather than blackening them. I used Duplicolor clear engine paint, and drilled shallow holes in a scrap piece of wood to hold them while spraying and drying. Overall, I think the blackened and clear-coated fasteners will work out great, but time will tell as to whether or not the Caswell stuff is as good as they say.
View attachment 2071 View attachment 2072
Next up was re-installing the gas tank, filler tube, and new rubber hose where appropriate. Piece of cake.
Next, I reinstalled the sub-frame and started on the suspension. It was a bit tight getting the sub-frame up into place by myself with only jack-stand clearance under the car, but it wasn't as bad as I expected. I balanced it on a floor jack under the diff, and worked it into place on the studs with my feet and one hand.
Once the suspension started going back together, I realized that the sway bar end links weren't going to line up properly with the lower control arms (LCA's).
Since I've never liked the stock links anyway, I decided to build my own and modify the LCA's. I wrote a tech article on it that can be found here.
View attachment 2064 View attachment 2065
After the links were installed, I finished assembling the rest of the suspension, and hung the rebuilt brake calipers and new rotors.
View attachment 2066 View attachment 2067
A final adjustment to the end links, lots of brake bleeding, and about 5 hours worth of shade-tree alignment finished things up, and it was back on the road and waiting for the next project...
awesome build, I love the black and white.
It's SOOOOOO clean. I love watching these updates on your car! Awesome work, man!
Thats sweet i just blasted my bolts, with glass bead, the parts still look great. Thats a nice coating though.
I just spent the last two hours reading ever update, and all the comments. I took some good notes :) I noticed that you painted a lot of your parts, there is another member on here that did a fuse box relocate to his glovebox that might be more anal than you, but he did a real cheap setup for doing your own powder coating. Crazy cheap to do, and the only seperate tool you need is an appliance that can be found all over for cheap (regular stovetop oven). I really enjoyed your build, the attention to detail is really good. Your catch can ideas where spot on, and I really like the overflow can. How soon before the interior?
Thanks for the compliments. ;)
That would be Eric you're referring to...and yes he is just a bit anal. LOL But it's worth it; his car is probably the cleanest in existence. I was going to have him and Brian do some PC for me, but I always ended up getting impatient or didn't have the funds, so out came the paint.
Not sure what you mean about the interior; it's in good shape. I did just mount a fire extinguisher to the sub box, and replaced the headliner a few months ago.
My latest project was installing an HX40, and I'm now working on a custom ignition setup. next will be another fuel pump when $$$ allows it, and one of these days I hope to get the exterior looking a bit nicer.
I'm jealous of your underbody LOL
Anyway yeah I had solid endlinks similar to yours, on the street they suck and make a ton of noise. I sliced some energy suspension universal sway bar bushings in half and stuck a couple washers on both sides. This way It's still stiff, but doesn't make a bunch of noise and require fabrication like you did.
Very nice though! I wish I had time to do things properly and make stuff look brand new - truth is I DD this car in winter and the winters around here just destroy cars IMO.
talonsnwbrdr;bt16356 said:
PART 24 - Interior!!!:) Couldn't stop readin. Love to see someone as OCD as me. Now i need to fund myself a rebuild. Honestly inspiring
LOL
Thanks. I actually have enough new stuff for 2 more entries, but this is most likely the last one due to the new thread format for the builds.
Appreciate the feedback!
