'92 TSI Complete Rebuild From Firewall Forward - Part 20
Calan
DSM Wiseman
7,250
400
Jan 16, 2007
OKC, Oklahoma
It's ALIVE!
It started right up, and other than a couple of very minor issues it has been running pretty well. The only real "problem" I've had so far is a weeping turbo oil feed line that just doesn't want to go away. It's not enough to even smoke or drip, but still...I'll probably end up going to a stainless line with AN fittings in the next week or so.
In the interest of being complete, I figured I better add one more post to wrap things up and cover the rest of the details.
The first of the remaining projects that I tackled was getting the fans and radiator mounted. Once the fans were attached to the radiator, I wired in the stock temp switch and tied them both together so that they both always run.
And then it was on to the J-pipe and lower IC piping. Pretty straight-forward stuff here.
View attachment 1152 View attachment 1153
Once the piping was complete, I put together a custom MBC and bracket, and mounted it behind the passenger-side headlight. Lines run through grommets in the rear headlight wall over to the J-pipe nipple and WGA actuator. The image below shows it before I inserted the grommets and ran the lines.
EDIT:
And here it is after I wired up the $0 DIY dual-stage boost controller I came up with. The second pic shows the "go faster" switch on the left side of the console. And before the ricer comments start flying, I have my reasons for needing to this. :)
View attachment 1163 View attachment 1164
I fabricated some "invisible" screens for the lower front clip to protect the oil cooler, IC, and air filter. I'm not a big fan of the obvious chicken-wire looking stuff, so these screens were made from a fine steel mesh, and painted black. This made them blend nicely with the white front clip, and the visible polished aluminum behind makes them almost unnoticable.
The screens were tightly formed to the back of the front clip, and are attached with small screws where the thickness of the fiberglass edges make it possible. I used heavy-duty zip ties across the top of the main opening.
View attachment 1159 View attachment 1160
After all the pre-start stuff was finished (filling/bleeding fluids, checking the electrical, etc.), I finally fired it up at 11:30pm Sep 23rd, and surprisingly it started immediately on the first crank. :hellyeah:
After setting the timing, BISS, and getting the ECU somewhat dialed in the next day, I took it around the block for the maiden voyage on Friday the 25th. The pic below shows the car when I first rolled it out of the garage, still missing the hood, headlights, heatshield, and a few other odds and ends. :)
One thing became immediately obvious...the vibration level wasn't gonna cut it. I'm no stranger to vibrating hotrods, but this was excessive. It felt like I had installed really good solid mounts rather than Prothanes, and I was only a day or two away from loosing the rear-view mirror and what little sanity I have left. :D
After a bit of detective work, I decided that the driver's side mount was the culprit. The problem was that:
1). The Prothane insert had very little flex, and more importantly
2). The inserts were too wide, causing them to bind in the frame mount and thus not allowing the mount to work as it's designed too.
Since I didn't have much to loose, I decided to experiment rather than go back to stock (and spend more $$$ I don't have). What I came up with was to drill two "arcs" made up of three 1/2" holes each, basically where the cutouts were in the stock mount, and two 3/8" holes at the front and back. This should provide some vibration damping without weakening the mount or making it soft-feeling.
BTW - The prothane inserts were surprisingly easy to machine; common drill and router bits left nice clean holes and surfaces, which usually isn't the case with rubber and some polyurethanes.
For the binding problem, I chucked up a 1/2" straight router bit in my drill press running at the highest speed, and milled 1/16" off the outer surface of each of the inserts. This allows the metal sleeve in the center to clamp properly in the frame, and gives the insert the clearance it needs to flex with the engine vibrations.
WARNING: If you try this, be sure to keep your fingers clear, hold the insert tightly, and use a sharp bit. It cuts pretty well, but like with any rubber or polyurethane, the bit can and will tend to grab a little. I accept no responsibility for missing finger tips or other body parts. :D
Notice in the last pic below that there is now some space between the sides of the inserts and the frame opening, which allows the mount to actually work as designed.
View attachment 1156 View attachment 1157 View attachment 1158
The improvement is like night and day. The violent shaking is completely gone, but it still has that firm feel to it and feedback from the motor/drivetrain is much more precise now.
Last but not least, the factory hood prop had to go. A trip to O'Reilly's and a bit of experimentation and number crunching yielded a pair of Mighty Lift hood struts. I welded nuts to the hood, and then notched the engine bay "rails" and welded nuts into them as well for the ball studs to screw into, and clipped the struts into place.
Although the struts are way nicer than the factory hood prop, the ones I bought are a bit too strong, and they are also VERY close to rubbing the hood. So I'll probably be tweaking them in the next few weeks for a better fit.
View attachment 1151 View attachment 1161
I'm also printing some custom decals (on automotive vinyl) for the engine bay fuse boxes. The image below shows the artwork; I'll edit this blog entry with another pic or two once they are installed.
Overall, I'm pretty pleased. It was a ton of work and a lot of time (around 750-800 hours at my best guess), but well worth it.
I've got around 250 miles on the motor now, and have it mildly tuned at 15psi. In the next few weeks (or days) I'll be upping that to 20psi and dialing it in. Future plans include that new built tranny that I couldn't afford this time around, and hopefully in a few months I'll be bolting on an HX35.
If any of you have questions on anything, send me an email or post it below. (I'll try to keep up with the questions and comments on here as much as possible).
Thanks for playing along!
Sweeeet. I like the MBC setup the most.
Nice build man, guess all that hard work really paid off! :thumb:
How did you mount the fans on the radiator? Were they bolts or are they zip tied, LOL? Looks good by the way. Thumbs up! :thumb:
Thanks for the kind words everyone. :)
I ended up mounting the fans with straight zip ties. The ones that came with the fans were crap, so I bought some heavy duty ones from Mr. Gasket that I've had good luck with in the past. I also installed weather stripping around the entire edge of each fan to help seal the shrouds and get them up off the radiator just a bit.
I wanted to make some brackets, but the combination of the tight fit and the fan/radiator layout meant that it would have been a real chore, if even possible.
damn sweet man!!
I just wish my rebuild would have started on firts crank... i would be as pleased as you if it did, even if my car isn't this clean!!
AMAZING job!!!!
goodluck with the hx35 too, i heard those are FUN!!
I've loved these blog entries, but why didn't you consider white for the engine bay back in Blog 5?
'Cause IMHO, a semi-flat black bay looks good no matter what color car it's sitting in. :D
White probably would have looked good as well...but with semi-flat black, the bay sort of dissapears and you find yourself taking in the actual engine detail. I just kept thinking back to my childhood model building days when every Revell model hotrod I built ended up with a black engine bay, and figured I couldn't go wrong. :)
BTW - I'm gonna KNOCK ON WOOD (several times) before saying this....but at 20psi the car spun all four 8-inch tires most of the way through second from a 25-30mph roll on dry asphalt today. Scared the shit out of me for a second, but it's a lot of fun. :rocks:
I get it now about the semi-flat black engine bay - kind of an homage to hot rods - nice.
8-inch tires?
I was wondering about what kind of power tools you have in your garage. I know that you have a bandsaw, drill press, belt sander, abrasive cabinet... but what brands/quality? Really I just want to see what it takes to do what you've done because it looks completely badass. :rocks::hellyeah:
8-inch tires?
yeah... BFG G-Force Sport 235/40 ZR 17's. Roughly an 8-inch wide contact patch.
Well I don't have a bandsaw, and out of everything I wish I did have, that is at the top of the list. I do have access to some at work which I used a few times for some of the aluminum pieces. A lot of the aluminum and steel cutting was done the old-fashioned way; brute force with a hacksaw, saber saw, and die grinder...not fun. Needless to say, my old Craftsman belt sander got a lot of use (turned up on it's handle and clamped in a vice).
Most of my tools are cheap. The blast cabinet is just a $199 Harbor Freight deal (which now needs a new gun), with a $40 Shop Vac attached to it. I also have a Makita electric die grinder from HF, along with a couple of really good (and expensive) carbide bits and some cheap cut-off wheels. The drill press is a Home Depot Ryobi...I think it was around $90 or so. My welder is a cheap 110v Lincoln Electric mig set up for steel. All those nice aluminum tig welds on the catch cans and such were done by a buddy of mine at work, who is one of the best tig welders I've seen.
Nice tools definitely make life easier, but they aren't absolutely necessary if you have the motivation and some patience. With that said, there are certain tools I couldn't do without (air compressor, drill press, gear wrench set, line wrenches, torque wrenches, belt sander, welder, and die grinder come to mind).
EDIT:
And oh yeah...can't forget about a good adjustable AN wrench. Expensive, but well worth it if you are going to be messing around with SS lines and annodized fittings.
Well I am extremely impressed at what you were able to accomplish with the tools you do have. We just purchased a new house with an 1100sqft garage and since this is the first house we've owned I am really wanting to get a permanent shop set up. So when I see something as awesome as what you've done here, I can't help but want to be able to emulate it. I've managed to gather a lot of hand tools over the years and a fairly nice compressor. I think an abrasive cabinet and drill press are going to be next on the list. Thanks for the quick reply and the tech guides that you've written over the course of this build. You are certainly an asset to the community.:thumb:
Thank you for that...it's appreciated.
Now that you have me thinking about it...
If I was building a new shop, a long work bench/cabinets with a good vice mounted to it would be first on my list, followed by the drill press, belt sander, and a band saw with a quality aluminum cutting blade. A high-flowing air compressor and air tools, blasting cabinet, chop saw with a steel cut-off wheel, and a decent tig welder would round out my top ten.
I didn't count the obvious things like hand tools (including a good flat file), and a place to store them. :D
Speaking of the bench and cabinets, I made mine from kitchen cabinet sections from Home Depot, along with a counter top for them as well. I pieced them together and leveled everything, and then screwed them together and mounted the top. A couple of inexpensive flourescent light ballasts were mounted under the top cabinets. The whole thing is about 10 ft. long, and I think it was around $700 when it was all said and done (maybe a bit more...I've drank a few beers and slept since then so I don't really remember).
My garage is trashed at the moment (one of my projects this weekend :rolleyes:), but here's a pic of the messy bench:
Granted, this is a good bit after the fact, but if you ever make those fuse box vinyls I would be interested in a set.
  • Wanted 6 bolt NT water pipe
    • chrisman287
