92 tsi build
92tsi5speed
Jan 4, 2010
indianapolis, Indiana
First off, I am new to DSM, I bought a 92 Talon TSI 5 speed. After about 100 miles the balace shaft belt broke. So now I am going to rebuild, with the intention of a low 11 second quater car if i havent set my goals to high LOL . Here is a list of what I have.
fresh 6 bolt .20 over
stock crank polished
manley rods
je pistons .20 over
85.5 cometic head gasket
arp head bolts, rod bolts, and main studs
stage 2 meth kit
bs elimenation kit
oem oil pump and water pump
a head that has been ported and polished 3 angle valve job, ferrea valves springs and retainers, hks 272/272 cams
eprom ecu with dsm link v2
bushur fpr
act 2600 and act strret liight flywheel
gates racing timing belt
walbro 255 fuel pump
afmic with 2 1/2 piping
aem wide band
auto meter auto lite
30 psi boost gauge volt meter oil pressure
I am also getting a maf and maf translator. What I need help with is what injectors to get, and what turbo I should get .
I was thinking about a HX 40 in a .70 bep housing. Any other suggestions?
As far as injectors I was thinking the bigger the better, but i'm not sure.
Any thoughts let me know!
Thanks
Chris
Gonna be a great build dude! Injectors do 1000cc's at least. You can scale for them with link! An HX-40 would probably be great! Precision has some turbos that would probably do awesome as well.
First build.. hoyl u go hard LOL.
sounds like u really do wanna run 11s
should put some pics up.
any ideas on what u want the car to look like.
what suspension,brakes and tires do u plan on running
I will post some pics soon motor is bein built at the machine shop as we speak hopefully i get it back this week. I bought a rebuilt hx40 pro goin to be putting a t3 .70 bep housing on it thinking about adding another walley 255 and some 1600cc injectors and running e85 so we will see how that works
my goals for the car are a weekend driver/racer. As of now my suspension is eibach lowering springs on stock struts i plan on getting some agx but that is later. Also i got stock brakes will upgrade but that is not a priority to me...(i just wanna go fast ha.ha) also i got newer mazda 6 wheels plan on running some reproduction mustang cobra wheels that are black like 5 spoke design there 18x10 Thanks for your replys
