GDNF2ET
- 586
- 11
- Feb 12, 2003
VA Beach,
Virginia
I put in a set of HKS 272's last week and it totally screwed up the launch...the car wouldn't make it past 2400rpm/3psi no matter what the tune. I put AFR between 13:5 and 9.5 and had ign timing at that point between 0* and 30*..it barely made any difference. It would sit for 10+ seconds at that 200-2450rpm and 2-3psi with no change.
So I pulled the 272 intake cam, put a stock 2g intake cam back in...bingo...now it will whip up to 3500+ and 15+psi (limit of my testing with street tires...it goes up in smoke with even that much power on the brakes).
Was that a 2g, stock, turbo, auto cam ? I've been tempted to try a pair of 1g, 2.0, NT auto cams just to see how it does...I would imagine the NT cams would be more aggressive since there's no turbo for power...
Good info here !!
Does it just make more heat? With the small housing and big boost/backpressure he's running I'd think less overlap would be ideal?
