My 1992 AWD Drag Talon build!
i just bought a piar of used sprints this weekend. I havent weighed the seats but i would say like around 5lbs mabie less.
I finally said Fu%k getting a t4 housing machined and got the BEP T3 .70 ar housing. Now someone needs to buy my t4 mani so i can get a t3.
So i got the BEP t3 housing for the hx40, Here are some pics. I also shot it with some 2000 degree primer then paint and baked it.<br />
<br />
<img src="http://img.photobucket.com/albums/v397/ihatejason/100_0280.jpg" border="0" alt="" /><br />
<br />
<img src="http://img.photobucket.com/albums/v397/ihatejason/100_0281.jpg" border="0" alt="" /><br />
<br />
<img src="http://img.photobucket.com/albums/v397/ihatejason/100_0282.jpg" border="0" alt="" /><br />
<br />
<br />
I shaved the compressor cover and also smoothed out texture from casting followed by a coat of high temp primer, high temp black paint, then cleared it. Pics are kinda dark but it came out pretty sweet, Nice and glossy.<br />
<br />
<img src="http://img.photobucket.com/albums/v397/ihatejason/100_0283.jpg" border="0" alt="" /><br />
<br />
<img src="http://img.photobucket.com/albums/v397/ihatejason/100_0288.jpg" border="0" alt="" /><br />
<br />
<img src="http://img.photobucket.com/albums/v397/ihatejason/100_0286.jpg" border="0" alt="" /><br />
<br />
<br />
Also today i orderd a ERL cast manifold
I painted the compressor housing with normal 500 degree paint (duplicolor), they have primer clear and lot of colors, and dont have to be baked.
The exhaust housing is the vht 2000 degree ceramic coating, they have clear but it satin not glossy.
I used the same coating how many coats did you use because mine is not that dark. Your not supposed to over coat anything it actually degrades the coating as a whole. Didn't make sense to me but I got that straight from VHT
I did 2 thin coats, Using there primer makes the black look alot richer, without the primer it comes almost dark brown looking.
That's true I didn't use primer but I cleaned mine with b101 and soap water and scuffed it with 400 so I knew it would stick. Looks good either way. Mine is a regular flat black I wouldn't say it's brown but you'll see for yourself if I can ever get the time to finish the body work the guy helping me is dragging his feet now.
Im getting a good powder coating gun and an oven and some real deal 2000 degree ceramic paint. Im going to be powdercoating my smim, intercooler pipes, valve cover, fuel rail. And then ceramic coating my exhast mani, compressor cover, turbine housing. As well as heat wrapping my erl manifold in black.
I will have 1000 hight temp powder, wrinkle black, satin black, semi gloss black. Then getting flat aluminum and flat black cermic paint, and a special paint gun for it. I cant wait to get all this stuff and do sandblasting, powder coating, ceramic coating, and painting.:thumb: The engine bay is gonna look awsome when im done with it.
Your gonna coat over the VHT? Will that work? Which company you going with for your coating? I was checking out a couple companies that made ceramic coating you can put in a paint gun but said for the gains seen in coating it wasn't worth putting to much stock into it but I am def curious to see how yours turns out.
Im going to sandblast everything first, not sure what company i am going to use but there are quite a few. The stuff im going to use is the same as all the big companys use and is industrial strength real deal stuff. You can use a small detail paint gun, but im going to get a special gun for it, and helps to get the paint inside the manifold as well. Tha part has to be sandblasted and cleaned then baked before you even shoot it, then cured a special way. Im probably going to quit my job and do side work full time, as well as powder coating, ceramic coating, painting and welding.
And hey when are you gonna buy that fuel cell off me?:D I want to sell it asap so i can order a 5 gallon instead.
You better get that stuff quick, im going to need my downpipe ceramic coated! :thumb:
Did you get you damn cell phone fixed yet, how am i supose to get ahold of you! Your short throw shifters done also. Craig put one in my car and it feels so lovely.
you should look into getting your aluminum parts anodized instead of powder coat. that always had a nice look, and might save you a few grams..LOL :thumb:
Well before you said you weren't selling it but if you are I might just have to come buy it off you after work today. Just let me know as I take it your phone doesn't work.
