1cleangsx
- 1,776
- 2,403
- Sep 28, 2013
Cheyenne,
Wyoming
No right now it’s engaging higher than it should, probably 3-4” off the floor, so I’m gonna back the rod a couple turns, away from the firewall so it engages about 2” or so off the floor as I believe that’s what Tim Zimmer said should be it’s proper engagement range. Since my pedal rebuild I had a Master Cylinder fail and a leaking slave, so I fixed all that and re bleed everything again, I’m just trying to find that sweet spot but haven’t yet
. I’m in Vegas this week but when I get back home I’m gonna try to adjust it one more time before I ditch this 2700lb plate and go with the 2300lb SS plate.
I might also pull the floor mat out as well for some extra luck
